Старый 09.04.2008, 00:05   #1
gatesasbait: Deleting of a Set of RecIds from multiple tables
Источник: http://gatesasbait.spaces.live.com/B...B9F5!203.entry
Good afternoon,
I use the following code when coding test cases. It allows me to create records, and delete them without having to manage every one separately. Inside my *test methods, I put the following set declaration and nested methods (I make sure to call deleteAll() even if an error was thrown during code execution):
 public void aTestMethodTest()
     Set recSet = new Set(Types::Container);
     void insert(Common _common)
        _common.doInsert();
        recSet.add([_common.TableId, _common.RecId]);
    void deleteAll()
        SetEnumerator setEnum = recSet.getEnumerator();
        SysDictTable sysDictTable;
        Common temp;
        RecId recId;
        TableId tableId;
         while (setEnum.moveNext())
            [tableId, recId] = setEnum.current();
            sysDictTable = new SysDictTable(tableId);
            temp = sysDictTable.makeRecord();
            select firstonly forupdate RecId
                from temp
                where temp.RecId == recId;
            ttsbegin;
            temp.doDelete();
            ttscommit;
     //(...) actual test case test code here
msdynamicsax: selecting data from multiple companyaccounts Blog bot DAX Blogs 0 28.08.2008 15:05
gatesasbait: System-generated find() and exist() methods on tables Blog bot DAX Blogs 0 06.08.2008 00:05
gatesasbait: Automatic creation of a PDF from a customer invoice in Dynamics Ax 4.0 Blog bot DAX Blogs 0 28.04.2008 19:05
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Говорят вышел SP2 для Axapta 3. Кто нибуть что знает на эту тему? soin DAX: Прочие вопросы 10 13.10.2003 10:43
Часовой пояс GMT +3, время: 17:16.
