Старый 31.01.2008, 20:50   #1
axStart: Import 3.0 company data into 4.0
Источник: http://axstart.spaces.live.com/Blog/...C0A0!253.entry
Sometimes the migration does not always works out. In that case we have to copy the data from 3.0 to 4.0 by hand.
As you know you can’t normally import 3.0 data into 4.0. If we compare the def files of 3.0 and 4.0 exports, we see some small differences. The changes are printed red in below example. After these changes you can import the 3.0
Changes to make:
· Change ver from 3.0.1 to 4.01
· Remove company from TableFef line
· Add line PTRECORDIDMIN with table id and value from RECORDIDMIN
· Add line PTRECORDIDMAX with table id and value from RECORDIDMAX
Of course this is not supported by MS and you get some errors while importing, but the data is there J
Код:
"EXPFORMAT VER. 3.0.1","Comma"
"TABLEDEF",50019,"Pro_TimeSheet","pro"
"RECORDDEF",50019,27,"ProjId",50001,"ActivityId",50002,"CategoryId",50003,"EmplId",50004,"LinePropertyId",50005,"TaxItemGroupId",50006,"TaxGroupId",50007,"CurrencyId",50008,"SalesPrice",50009,"costPrice",50010,"Txt",50011,"Dimension",50012,"Dimension",50012,"Dimension",50012,"FromTime",50013,"ToTime",50014,"HoursDay1",50015,"HoursDay2",50016,"HoursDay3",50017,"HoursDay4",50018,"HoursDay5",50019,"HoursDay6",50020,"HoursDay7",50021,"PeriodStartDate",50022,"PostedJournalId",50023,"PostedDate",50024,"Posted",50025
"RECORDCOUNT",50019,2663
"RECORDIDMIN",8738
"RECORDIDMAX",141814
"CREATEDTRANSIDMIN",0
"CREATEDTRANSIDMAX",0
"MODIFIEDTRANSIDMIN",0
"MODIFIEDTRANSIDMAX",0
"RECORDCOMPANY","pro"
"EXPFORMAT VER. 4.01","Comma"
"RECORDDEF",50019,28,"ProjId",50001,"ActivityId",50002,"CategoryId",50003,"EmplId",50004,"LinePropertyId",50005,"TaxItemGroupId",50006,"TaxGroupId",50007,"CurrencyId",50008,"SalesPrice",50009,"costPrice",50010,"Txt",50011,"Dimension",50012,"Dimension",50012,"Dimension",50012,"FromTime",50013,"ToTime",50014,"HoursDay1",50015,"HoursDay2",50016,"HoursDay3",50017,"HoursDay4",50018,"HoursDay5",50019,"HoursDay6",50020,"HoursDay7",50021,"PeriodStartDate",50022,"PostedJournalId",50023,"PostedDate",50024,"Posted",50025,"recVersion",61450
"PTRECORDIDMIN",50019,8738
"PTRECORDIDMAX",50019,141814
"RECORDIDMIN",8738
axStart: Change data on a data source on a Form Blog bot DAX Blogs 0 04.09.2008 15:05
axStart: Make country configuration key company depended. Blog bot DAX Blogs 0 09.02.2008 06:57
axStart: How to convert a column in a table to a different type with the same name without losing data. Blog bot DAX Blogs 0 01.02.2008 21:21
Arijit Basu: PerformancePoint Server 2007 Tool: Data Import Wizard for Microsoft Dynamics AX Blog bot DAX Blogs 0 22.01.2008 21:33
Axapta Lessons: Using X++ Code during Data Import Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 02:55.
