Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 09.01.2007, 02:17   #1
gb is offline
gb
? InventTable form is empty
Hello,
I have a strange behaviour of InventTable form in my development environment ( AX3 + sp2 + KR2)
When I open this form it shows no records, although, InvnetTable, InventTableModule, and InventItemLocation have all records. If I disable innerJoin on InventItemLocation datasource then I get all records on the form and an error message thrown by kernel:
"Query does not contain 5 data source(s)."
If I disable InnerJoin on Purch datasource then I again get all the records and four similar error messages:
"Query does not contain 2 data source(s)."
"Query does not contain 3 data source(s)."
"Query does not contain 4 data source(s)."
Same form works fine in Production and Testing environment.
Has anybody seen this? Any suggestions?
Thanks,
gb
Старый 09.01.2007, 15:39   #2
slava09 is offline
slava09
Аватар для slava09
Дети Юза
1C
1,642 / 237 (11) ++++++
Have you records in InventItemLocation where field InventDimId = 'Axapta' for each record in InvnetTable ?
Have you 3 records in InventTableModule for each record in InvnetTable ?
Старый 09.01.2007, 16:15   #3
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
The explanation for the messages you are getting is simple:
All operations with the datasources on the InventTable form are performed using the method dataSourceNo(), so in order for the form to work properly you must have 5 datasources connected.
As for the error with the missing records, I think it has to be due to one of your previous modifications.
Have you added more datasources to the form?
And do check what slava09 wrote in his post above - the InventDimId for the records in InventItemLocation has to equal the one specified in method findOrCreateBlank of InventDim table (by default, it is 'Axapta')
Старый 09.01.2007, 16:24   #4
gb is offline
gb
Yes, that is all in place..
The form was working fine before. Something happened a few days ago and it stopped working properly. Interesting thing is that if I add new record to InventTable, then it will show up in the form, but all existing records are not shown. I compared new records in InventTable and InventTableModule and InventItemLocation and they all look similar.
Старый 10.01.2007, 20:28   #5
gb is offline
gb
I found my problem and solution. The globalIventDimId was set to default Axapta, while we use DIM000001 as an "empty" dim Id.
Clearing the cache resolved the issue.
Regards,
gb
dax-lessons: Problem when creating a dynamic form with ActiveX control & Solution :) Blog bot DAX Blogs 0 30.04.2008 16:05
Axapta Lessons: Trapping keystrokes in a Form Blog bot DAX Blogs 13 01.11.2006 18:16
Программно записи в InventTable djoker DAX: Программирование 8 02.12.2004 16:59
Говорят вышел SP2 для Axapta 3. Кто нибуть что знает на эту тему? soin DAX: Прочие вопросы 10 13.10.2003 10:43
Не отображается товары в Form\InventTable! Zelenhof DAX: Программирование 6 15.01.2003 17:55
Часовой пояс GMT +3, время: 04:17.
