Старый 22.11.2019, 18:11   #1
25,475 / 846 (79) +++++++
crmtipoftheday: Tip #1315: How to remove Field Service from Dynamics 365
Источник: https://crmtipoftheday.com/1315/how-...-dynamics-365/
Disclaimer for Ben Vollmer: We love field service. If it was food, we would eat it at every meal.
That out of the way, sometimes you find yourself with solutions in your environment that you don’t need. Maybe you set up a trial of Dynamics 365 and you accidentally chose the “I want it all” option and wound up with a bunch of managed solutions in your environment. This can be bad, as any solution you develop in this environment will have a dependency on these solutions, requiring you to install them before you can move your solution.
If you find yourself in this situation, you will want to remove these solutions from your environment. But that can be challenging, as many of these apps install multiple solutions in your environment.
In this video tip, I show you how to determine the order in which these solutions should be removed and then successfully uninstall field service from a Dynamics 365 environment.
I removed Field Service and lived to tell the taleI did see the Skyline Consulting blog on this topic, but it is outdated as the solutions are now different.
Tips for uninstalling first-party apps:
  1. Sort solutions in descending order–that generally tells you which solutions to remove first
  2. Remove patch solutions before removing the main solutions
  3. When in doubt, go to the components list in classic solution manager, select one of the entities in the app and click “solution layers.” This gives you information about the layers, remove the higher layers first.
  4. When you hit a dependency notice when deleting the solution, remove the dependency, then delete the solution.
The following is the order of operations from the video:
  • msdyn_FieldServiceTrial
  • msdyn_FieldServiceGeofencing
  • Remove Geofencing SDK step
  • msdyn_Geofencing_Patch_1
  • msdyn_IoTHealth
  • msdyn_IoTProviders_Patch_1
  • IoTProviders
  • msdyn_CFS_Patch_1
  • ConnectedFieldService
  • msdyn_IoT_Patch_1
  • IoTConnector
  • msdynce_FieldServiceHealth
  • msdyn_FieldService_Patch_6
  • remove msdyn_/Utils/head.js from user form
  • remove msdyn_/Utils/head1.0.3.js from contact form
  • FieldService
crmtipoftheday: Tip #1300: CDS vs Dynamics 365 instances Blog bot Dynamics CRM: Blogs 0 03.09.2019 16:11
msdn.microsoft.com/nav: Latest update of Dynamics 365 Guides adds Dynamics 365 for Field Service integration (Preview) Blog bot NAV: Blogs 0 24.07.2019 00:14
stoneridgesoftware: Webinar: When & How to Upgrade from Dynamics AX to Dynamics 365 for Finance & Operations Blog bot DAX Blogs 0 06.04.2018 06:15
crmtipoftheday: Tip #1098: Dynamics 365 Connected Field Service Demo Builder Blog bot Dynamics CRM: Blogs 0 05.04.2018 17:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
Часовой пояс GMT +3, время: 07:51.
