Старый 15.02.2019, 17:11   #1
25,448 / 846 (79) +++++++
crmtipoftheday: Tip #1221: Need entity permission for dynamics lookup filters
Источник: https://crmtipoftheday.com/1221/need...ookup-filters/
Entity lists in Dynamics 365 Portals include a cool Metadata Filter feature that creates a faceted search over the content of your list. You can filter using text, ranges of values, lookups, optionsets, and even custom FetchXML filter.
When you filter by a lookup, you can use a list of static values in your filter, or you can create a Dynamic Lookup Set that would use a view.
Let’s say I have an entity list displaying contacts and I would like to filter them by the currency (yes, I always filter by the money-related matters, that’s how you separate acquaintances from friends). So this is what Dynamic Lookup Set looks like:
That was easy, right? Let’s see the filter in action.
What the heck? I swear I added солкуобай just this morning! And I can see currencies for individual contacts in the list?!
Turns out, regardless whether your entity list uses them or not, entity permissions still apply to the dynamic lookups. After adding Global Read permission on currencies for everyone, the filter is up and running.
Here you go, my солкуобай is there, safe and sound.
(Cover photo by Tyler Nix on Unsplash)
crmtipoftheday: Tip #1207: Check applied entity permissions in portals Blog bot Dynamics CRM: Blogs 0 10.12.2018 17:11
crmtipoftheday: Tip #1197: Unified Interface lookup changes Blog bot Dynamics CRM: Blogs 0 22.11.2018 17:13
crmtipoftheday: Tip #1190: Searchable lookup and relationship Blog bot Dynamics CRM: Blogs 0 12.11.2018 15:11
crmtipoftheday: Tip #1044: Display lookups as hyperlinks in portal entity list Blog bot Dynamics CRM: Blogs 0 15.12.2017 03:21
crmtipoftheday: Tip #1024: Make an entity regarding available from Outlook App Blog bot Dynamics CRM: Blogs 0 16.11.2017 20:11
Часовой пояс GMT +3, время: 14:08.
