Старый 15.02.2019, 03:21   #1
25,475 / 846 (79) +++++++
waldo: C/AL Source Code Analysis with PowerShell
Источник: https://dynamicsuser.net/nav/b/waldo...ith-powershell
Last Directions US and EMEA, I had the opportunity to talk about – uhm – myself. Well, not really – about my tools. It was a weird experience – but it got more attention than I ever expected.
Now, during that session, I showed a tool that I wanted to put out there for sooooo long: a way to analyze your C/AL Source Code with PowerShell.
This was actually an “let’s see what we can do and how far we can go”-challenge during our free time ;-), where the .Net part (which is the majority of the work) wasn’t done by me, although I was quite (let’s say “overly”) involved with the entire evolution of it ;-). The tool might not be completely new to you. I have been using it for quite some time to talk about some things within the product, like:
So as you can see – it’s basically about analyzing C/AL code.
Also at NAVTechDays, I spent a topic on it during my session with Vjeko. You can see it here:
The Tool
When we talk about the tool, we call it the “ModelToolsAPI“. It’s a PowerShell-module-dll that my partner in crime wrote, “on top of” the existing “Microsoft.Dynamics.Nav.Model.Tools.dll”, which is a library that serves the PowerShell Merge-CmdLets provided by Microsoft. It basically builds you an Object Model from your text files, which it needs to be able to merge in a smart way. For example, the tool knows all objects, or properties, what fields, relationships, … and a hell-of-a-lot more. And simply said: when you have an object model, you can work with it. When you only have a text-file, all you can do is search in text.
And I was wondering – what if we could do this in PowerShell? Because simply, I don’t know what I want to analyze today, and how I want the output to look like. Or better yet – what if I want to make the analysis part of my build, or commit, or pull request, or .. you know what I mean: part of my integration scenario! For analyzing code, PowerShell all of a sudden made all the sense in the world! At least for us ;-).
But we saw two problems with the out-of-the-box “Microsoft.Dynamics.Nav.Model.Tools”:
  • It sees code as just text – so it doesn’t really “understand” code. And with understand, I mean:
    • being able to trace fields, variables, procedures, keys, .. back to where they are used in code
    • Understand an “if” statement and any other statement for that matter
    • Being able to track complexity of a certain procedure
  • Its default object structure was quite complex.
So, my fellow nerd started to crunch a better, more understandable object model out of it, and started to write a code tokenizer (if I can call it like that) for C/AL code, basically mapping all words in code to something it understands.
As a result, we have a complete object model, understanding code, which we can query any way we like. Even more, because we’re using the default “Microsoft.Dynamics.Nav.Model.Tools”, we also have its modification- and export-functionality at our disposal (you hear me coming? ControlIDs? .. (but that’s for a later blogpost) :-)). And still even more, because (again) we are using default Microsoft libraries, with an update, we simply tap into the new version, and off we go :-).
Where can I find it?
I understand it’s not going to be easy to get started with a tool like this. But if you pick up the challenge, you won’t regret it! I tried to make it as approachable as at all possible:
Once you get used to it, it’s super-readable!
Now it’s up to you!
There are quite a number of scenarios where we apply this tool.
Just now, we are about to rewrite our product in AL. With this tool, we did a complete, in depth dependency analysis for figuring what apps we would end up with. It gave us an overview of problems with “circular dependencies”, and an easy way to document all changes we did for certain modules/apps. I’m definitely coming back to that exercise!
We also used this for figuring out and fixing controlid-errors – if you ever encountered them, you sure know what I’m talking about! ;-).
And much much more – basically, it’s a bit up to you to get familiar with it (if you at least want it to be), and apply it on whatever you want to apply it.
Expect more scripts and blogs about this in the future, but please do know you can contribute as well (just fork and make a pullrequest), … .
Enjoy!
waldo: Enable the updated Code Analysis for AL Blog bot NAV: Blogs 0 26.03.2018 08:11
waldo: Enable Code Analysis for AL Blog bot NAV: Blogs 0 23.01.2018 08:12
waldo: Microsoft Dynamics NAV Source Code Analysis – Triggers & Procedures Blog bot NAV: Blogs 0 09.03.2017 04:17
waldo: Microsoft Dynamics NAV Source Code Analysis – LineCount Blog bot NAV: Blogs 0 02.03.2017 07:14
Часовой пояс GMT +3, время: 11:44.
