Сообщение от
EvgenijM
Код:
function GetAttributeValueByEntityId(entityName, entytiId, attributeName)
var xml = '' +
'[?xml version=`1.0` encoding=`utf-8`?]' + '\r\n' +
'[soap:Envelope xmlns:soap=`http://schemas.xmlsoap.org/soap/envelope/` xmlns:xsi=`http://www.w3.org/2001/XMLSchema-instance` xmlns:xsd=`http://www.w3.org/2001/XMLSchema`]' + '\r\n' +
' [soap:Body]' + '\r\n' +
' [entityName xmlns=`http://schemas.microsoft.com/crm/2006/WebServices`]' + entityName + '[/entityName]' + '\r\n' +
' [id xmlns=`http://schemas.microsoft.com/crm/2006/WebServices`]' + entytiId + '[/id]' + '\r\n' +
' [columnSet xmlns=`http://schemas.microsoft.com/crm/2006/WebServices` xmlns:q=`http://schemas.microsoft.com/crm/2006/Query` xsi:type=`q:ColumnSet`]' + '\r\n' +
' [q:Attributes]' + '\r\n' +
' [q:Attribute]' + attributeName + '[/q:Attribute]' + '\r\n' +
' [/q:Attributes]' + '\r\n' +
' [/columnSet]' + '\r\n' +
' [/soap:Body]' + '\r\n' +
'[/soap:Envelope]' +
xml = xml.replace(/\[/gi, String.fromCharCode(60));
xml = xml.replace(/\]/gi, String.fromCharCode(62));
xml = xml.replace(/\`/gi, String.fromCharCode(34));
var xmlHttpRequest = new ActiveXObject('Msxml2.XMLHTTP');
xmlHttpRequest.Open('POST', '/mscrmservices/2006/CrmService.asmx', false);
xmlHttpRequest.setRequestHeader('SOAPAction','http://schemas.microsoft.com/crm/2006/WebServices/Retrieve');
xmlHttpRequest.setRequestHeader('Content-Type', 'text/xml; charset=utf-8');
xmlHttpRequest.setRequestHeader('Content-Length', xml.length);
xmlHttpRequest.send(xml);
var doc = xmlHttpRequest.responseXML;
// alert(xmlHttpRequest.responseText);
var retValue = '';
if (doc.selectSingleNode('//RetrieveResult/' + attributeName) != null) retValue = doc.selectSingleNode('//RetrieveResult/' + attributeName).text;
return retValue;
Использовать в OnChange поля продукта, например:
Код:
var oProduct = crmForm.all.productid;
if (oProduct.DataValue != null && oProduct.DataValue[0] != null)
crmForm.all.SOME_OTHER_FIELD.DataValue = GetAttributeValueByEntityId('product', oProduct.DataValue[0].id, 'PRODUCT_ATTRIBUTE_NAME');
Сообщение с веб-страницы
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<soap:Fault>
<faultcode>soap:Client</faultcode> <faultstring>System.Web.Services.Protocols.SoapException: Сервер не распознал заголовок HTTP SOAPAction:
http://srv/mscrmservices/2006/WebServices/Retrieve. at System.Web.Services.Protocols.Soap11ServerProtocolHelper.RouteRequest() at System.Web.Services.Protocols.SoapServerProtocol.Initialize() at System.Web.Services.Protocols.ServerProtocolFactory.Create(Type type, HttpContext context, HttpRequest request, HttpResponse response, Boolean& abortProcessing)</faultstring>
<detail />
</soap:Fault>
</soap:Body>
</soap:Envelope>
ОК
Уже кучу способов перепробовал, а результат один
. Подскажите пожалуйста, в чем моя ошибка?
