16.03.2013, 15:12
#1
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework (Old name - Data Migration Framework) is now available on Information source
Источник: http://blogs.msdn.com/b/axsa/archive...on-source.aspx
Link :- https://informationsource.dynamics.com//RFPServicesOnline/Rfpservicesonline.aspx?ToolDocName=Microsoft+Dynamics+AX+2012+Data+Import%2fExport+Framework%7cQJ4JEM76642V-8-1005
Some of the key features -
- 70 Entities out of the box ( 40+ new entities added) - Master Data, Reference Data, Journals, etc
- Support for creating custom entities using Custom entity creation wizard.
- Support for AX 2012 RTM, R1 and R2.
- Support for SQL 2008 and SQL 2012
- Import Entity data from multiple sources - Flat File:-Delimited and Fixed Width, ODBC :– external data bases, Excel, etc.
- Export Entity data from AX 2012 to - Other AX 2012 environments, Flat File
- Copy Entity data across Legal entities
- Entity types – Entity, composite entity and flat table.
- Mapper control
- Parallel execution support from staging to target using Task Bundling
- Folder as input for running periodic import - with functionality to move files to different folders (In Process, Error and Completed)
- Error handling - skipping error rows, etc.
- Set based support for staging to target
- Default value Support
- Number sequence Support
- External Key mapping Support
- Source to Target in single step
- Multiple AOS support
