Источник:
http://alexvoy.blogspot.com/2023/04/x-to-run-xirr.html
I created a small X++ wrapper to call
XIRR function from the C# project provided by
https://github.com/klearlending/XIRR (Thank you!)
You can test XIRR function in Excel, btw.
using tmxExcelFinance;
/// /// Implements various financial functions/// public final
class mgcFinanceFunction{
/// /// Calculates XIRR value /// /// List of containers kind [cashflow amount, its date] /// how many decimals to calculate /// Maximum rate /// XIRR value public static real
calculateXIRR(List _cashFlows,
int _decimals, real _maxRate =
1000000) {
var cashFlows =
new System.Collections.Generic.List(); System.Collections.IEnumerable cashFlowsI; ListEnumerator leC = _cashFlows.getEnumerator(); System.Double dbl; System.DateTime dt;
while(leC.moveNext()) {
[dbl, dt] = leC.current(); cashFlows.Add(
new CashFlowDates(dbl, dt)); }
// convert to iterable cashFlowsI = cashFlows;
return XIRR::Calc(cashFlowsI, _decimals, _maxRate); }}
This is how we can call the wrapper
public static void calculateXIRRFromInvestmentDetailsLineTmp(RefRecId _projTableRecId, mgcInvestmentDetailsLineTmp _mgcInvestmentDetailsLineTmp) { List listCashFlowsDates =
new List(Types::Container); mgcInvestmentDetailsLineTmp mgcInvestmentDetailsLineTmpLocal; mgcInvestmentDetailsLineTmpLocal.linkPhysicalTableInstance(_mgcInvestmentDetailsLineTmp);
while select mgcInvestmentDetailsLineTmpLocal { listCashFlowsDates.addEnd([mgcInvestmentDetailsLineTmpLocal.TransactionCurrencyAmount, DateTimeUtil::newDateTime(mgcInvestmentDetailsLineTmpLocal.LineDate,
0)]); } mgcProjXIRRTable.XIRRValue = mgcFinanceFunction::calculateXIRR(listCashFlowsDates,
4);...
Or
cashFlows1 =
new List (Types::Container); cashFlows1.addEnd([-
10000,str2Date("01/01/2008",
123)]); cashFlows1.addEnd([
2750, str2Date("01/03/2008",
4250, str2Date("30/10/2008",
3250, str2Date("15/02/2009",
2750, str2Date("01/04/2009",
123)]);res = mgcFinanceFunction::calculateXIRR(cashFlows1,
10);
Notes about the solution creation.
D365FO project must be v4.6
Last remark. I tried to implemented the same algorithm in X++, but I bumped into two limitations.
First, there is a limit for recursion depth - 400 levels; we can flatten it, though.
Second, real loses required decimals and ends up with division by zero.
Источник:
