Когда пишите код на панели есть кнопочка X++
Извините не заметил
void method1()
ProdTable ProdTabl;
ProdBOM ProdBom;
LoginProperty LP = new LoginProperty();
OdbcConnection myConnection;
Statement myStatement;
ResultSet myResult,myResultLine;
Str s;
str 50 CRProdid,Item;
real LostQty,DifQty;
prodTableChangeQtySched PQS = new prodTableChangeQtySched();
ProdTabl = ProdTable;
ProdBom = ProdBOM;
LP.setDSN("TransferConnection");
info(ProdTabl.collectrefprodid);
try
myConnection = new OdbcConnection(LP);
myStatement = myConnection.createStatement();
myResult = myStatement.executeQuery(
strfmt("Select excontrolqty,primor,collectrefprodid from ShiftReportPourHeader " +
"Where DataAreaId = '%1' and collectrefprodid = '%2'",
curext(),ProdTable.collectrefprodid));
while (myResult.next())
{ s = int2str(myResult.getInt(2));
CRProdid=myResult.getString(3);
info(s);
myResultLine = myStatement.executeQuery(strfmt("Select CAST(LostQty AS numeric(15, 8)) AS exp1,CAST(DiffectQty AS numeric(15, 8)) AS exp1,ItemId from ShiftReportPourLine " +
"Where primor = '%1'",s));
while (myResultLine.next())
Item=myResultLine.getString(3);
LostQty=myResultLine.getReal(1);
info(num2str(LostQty,6,3,1,1));
ttsbegin;
select forupdate * from Prodbom where Prodbom.ProdId==CRProdid && Prodbom.ItemId==Item;
info('Go');
Prodbom.ScrapConst =LostQty;
ttscommit;
ttsbegin;
info('go2');
Prodbom.update();
ttscommit;
info('go2');
ProdTabl.QtySched=myResult.getReal(1);
PQS.parmProdTable(ProdTable);
myStatement.executeUpdate(strfmt("Update ShiftReportPourHeader Set posted = 1 Where primor = %1 (1 = 0)", s));
if(!s)
throw ('Нет данных для импорта');
catch
throw("Check DSN settings (username/password).");
