Тема: Горе .NET
Старый 22.05.2018, 08:45   #11
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Вот есть такое мнение.
https://stackoverflow.com/questions/...jrebel-for-net
There is no such thing in the .net world.. not so powerful.. there are some thing like Edit and Continue but this is like "Hot replace" in Java and nothing more. The problem is in .net you have the whole model of .dll(s) with their versions and dependencies between dlls pointing to specific version so it is not possible to replace dll without replacing all.
An workaround will be something like compiling the classes, adding tons of assembly redirects, somehow unloads and loads the old dll but it is hell of a hard.
Keep in mind that in java after the "module" JSR is implemented maybe in java 9 we will not have JRebel as well.
