Старый 10.08.2018, 11:20   #327
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Как-то так:
custVendTrans.ReasonRefRecId = reasonRefRecID;
        // If the amount, which is the total invoice amount, is zero, then the amountMST and amountCur also must be zero
        if (amountCur)
            if (_useSubLedger)
                // <GIN>
                if (TaxWithholdParameters_IN::checkTaxParameters())
                    amountCur += taxWithholdAmount;
                // </GIN>
                custVendTrans.AmountMST = CurrencyExchangeHelper::mstAmount(amountCur, currencyCode, transDate, Currency::noYes2UnknownNoYes(triangulation), exchRate, exchRateSecondary);
            else
                // <GEERU>
                if (ledgerBalances)
                    custVendTrans.AmountMST = CurrencyExchangeHelper::amount(postedAmountMST, Ledger::accountingCurrency());
                else
                    // </GEERU>
                    custVendTrans.AmountMST = CurrencyExchangeHelper::amount(ledgerPostingReference.lastAmountMST(), Ledger::accountingCurrency());
                    // <GEERU>
                // </GEERU>
        else
            custVendTrans.AmountMST = 0;
 /// <summary>
    /// Calculates the total of the multiple posted balance amount based on
    /// the specific currency code and the object of <c>CurrencyExchangeHelper</c>.
    /// </summary>
    /// <param name = "_curencyCode">The transaction currency originating the conversion.</param>
    /// <param name = "_currencyExchangeHelper">The <c>CurrencyExchangeHelper</c> class which manages calculations between currencies.</param>
    /// <returns>A container of AmountCur and AmountMst.</returns>
    private container calculatePostedMultipleBalanceAmounts_RU(CurrencyCode _curencyCode, CurrencyExchangeHelper _currencyExchangeHelper)
        int i;
        boolean correction;
        AmountCur balanceValue;
        AmountCur retAmountCur;
        amountMST retAmountMst;
        for (i = 1; i<=conLen(ledgerBalances); i++)
            [correction, balanceValue] = conPeek(ledgerBalances, i);
            retAmountCur += balanceValue;
            retAmountMST += _currencyExchangeHelper.calculateTransactionToAccounting(
                    _curencyCode,
                    balanceValue,
                    true
        return [retAmountCur, retAmountMst];
if (countryRegion_RU)
            custVoucher.parmSalesInvoicePostingType_RU(custInvoiceJour_RU.InvoicePostingType_RU);
            if (this.postBalanceAsManyLedgerTransactions_RU())
                custVoucher.parmLedgerBalances_RU([[false, salesTotals.totalAmountBySign_RU(false)], [this.parmStorno(), salesTotals.totalAmountBySign_RU(true)]]);
