Сюда запощу код на всякий случай, а то говорят с той ссылкой что-то не так
X++: using System;
using System.IO;
using System.Drawing.Printing;
using System.Runtime.InteropServices;
using System.Windows.Forms;
namespace Printer
public class RawPrinterHelper
[StructLayout(LayoutKind.Sequential, CharSet = CharSet.Unicode)]
public struct DOCINFOW
[MarshalAs(UnmanagedType.LPWStr)]
public string pDocName;
public string pOutputFile;
public string pDataType;
[DllImport("winspool.Drv", EntryPoint = "OpenPrinterW", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Unicode, SetLastError = true, ExactSpelling = true)]
public static extern bool OpenPrinter(string src, ref IntPtr hPrinter, int pd);
[DllImport("winspool.Drv", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Unicode, SetLastError = true, ExactSpelling = true)]
public static extern bool ClosePrinter(IntPtr hPrinter);
[DllImport("winspool.Drv", EntryPoint = "StartDocPrinterW", CallingConvention = CallingConvention.StdCall, CharSet = CharSet.Unicode, SetLastError = true, ExactSpelling = true)]
public static extern bool StartDocPrinter(IntPtr hPrinter, int level, ref RawPrinterHelper.DOCINFOW pDI);
[DllImport("winspool.Drv", EntryPoint = "EndDocPrinter", SetLastError = true, CharSet = CharSet.Unicode, ExactSpelling = true, CallingConvention = CallingConvention.StdCall)]
public static extern bool EndDocPrinter(IntPtr hPrinter);
[DllImport("winspool.Drv", EntryPoint = "StartPagePrinter", SetLastError = true, CharSet = CharSet.Unicode, ExactSpelling = true, CallingConvention = CallingConvention.StdCall)]
public static extern bool StartPagePrinter(IntPtr hPrinter);
[DllImport("winspool.Drv", EntryPoint = "EndPagePrinter", SetLastError = true, CharSet = CharSet.Unicode, ExactSpelling = true, CallingConvention = CallingConvention.StdCall)]
public static extern bool EndPagePrinter(IntPtr hPrinter);
public static extern bool WritePrinter(IntPtr hPrinter, IntPtr pBytes, int dwCount, ref int dwWritten);
public static bool SendBytesToPrinter(string szPrinterName, IntPtr pBytes, Int32 dwCount)
IntPtr hPrinter = System.IntPtr.Zero;
Int32 dwError;
DOCINFOW di = new DOCINFOW();
Int32 dwWritten = 0;
bool bSuccess;
di.pDocName = "My Document";
di.pDataType = "RAW";
bSuccess = false;
if (OpenPrinter(szPrinterName, ref hPrinter, (int)0))
if (StartDocPrinter(hPrinter, 1, ref di))
if (StartPagePrinter(hPrinter))
bSuccess = WritePrinter(hPrinter, pBytes, dwCount, ref dwWritten);
EndPagePrinter(hPrinter);
EndDocPrinter(hPrinter);
ClosePrinter(hPrinter);
if (bSuccess == false)
dwError = Marshal.GetLastWin32Error();
return bSuccess;
public static bool SendFileToPrinter(string szPrinterName, string szFileName)
FileStream stream1 = new FileStream(szFileName, FileMode.Open);
BinaryReader reader1 = new BinaryReader(stream1);
byte[] buffer1 = new byte[((int)stream1.Length) + 1];
buffer1 = reader1.ReadBytes((int)stream1.Length);
IntPtr ptr1 = Marshal.AllocCoTaskMem((int)stream1.Length);
Marshal.Copy(buffer1, 0, ptr1, (int)stream1.Length);
bool flag1 = RawPrinterHelper.SendBytesToPrinter(szPrinterName, ptr1, (int)stream1.Length);
Marshal.FreeCoTaskMem(ptr1);
return flag1;
public static void SendStringToPrinter(string szPrinterName, string szString)
IntPtr pBytes;
Int32 dwCount;
dwCount = szString.Length;
pBytes = Marshal.StringToCoTaskMemAnsi(szString);
MessageBox.Show(pBytes.ToString());
SendBytesToPrinter(szPrinterName, pBytes, dwCount);
Marshal.FreeCoTaskMem(pBytes);
