soin
Я устанавливать не пробовал, но могу поучаствовать в разборе проблем
Интересно, может скоро самому придется ставить.
В чем собственно проблема?
Обще познавательные линки:
- http://gatesasbait.spaces.live.com/B...B9F5!235.entry
- http://msdynamicsax.wordpress.com/20...d-ms-sql-2008/
- Microsoft Dynamics AX 2009 Installation Guide
http://dynamicsuser.net/media/p/137794.aspx
Install required components
Reporting extensions
Checklists for installing the reporting extensions
Install prerequisites on the report server
Configure Reporting Services
Configure Reporting Services 2005 on Windows Server 2008
Update the Reporting Services configuration file
Install the reporting extensions
Deploy reports
Set up the reports
- Installing AX 2009 Reporting Extensions in MSSQL 2008 & WIN 2008
http://daxguy.blogspot.com/2008/12/i...xtensions.html
When we try to install AX 2009 SP1 Reporting Services on a PC running SQL 2008,we get an error saying that MSSQL 2005 SP2 is required. Well there is a solution to this issue which is as follows:
1. Locate the AX Reporting services dll from the extracted AX 2009 SP1 folder
[\\AX2009SP1\support\axsetupresources\microsoft.dynamics.setup.reportingservices.dll;File Version - 5.0.1000.52]
2. Extract the AX 2009 .iso to a shared folder
3. Copy the microsoft.dynamics.setup.reportingservices.dll into the folder:
\\DynamicsAX\Msi\Components32\Program Files\Microsoft Dynamics AX\50\Setup
\\DynamicsAX\Msi\Components64\Program Files\Microsoft Dynamics AX\50\Setup
4. It will ask to replace the existing dll having File Version - 5.0.593.0. Say Yes and replace.
5. Then Install AX Reporting Services extensions. It works fine and the Reporting Extensions are installed nice.
