Источник:
https://organicax.com/2016/09/21/wor...acking-report/
If you are looking for some details about what is running in workflow then you can look at a few different reports you can find in organization management. One of these is the workflow tracking report. It will give you the basic information about status of the workflow the current step it’s on and how it’s assigned to. There are a number of reasons this could be useful. For example seeing what workflows are usage if you need to change rules.
These reports work off the cubes so the data is only as good as the last time you processed the cubes.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under:
Workflow
Источник:
