Тема
axblog4u: Multiple XPO Import Version – 2
25.01.2011, 22:11
1
846
79
Источник:
http://axblog4u.wordpress.com/2011/0...ort-version-2/
Hi folks
There was a major issue in the version 1 of the Multiple XPO Import tool. Each time when a multiple XPO’s are imported, a confirmation dialog keeps popping up for all the existing elements. This behavior seems to be very annoying to the users.
Now the code design pattern is slightly modified. When an import is performed all the objects are imported SILENTLY without confirmation dialog show up to users even for existing elements.
Note: Please use at your own risk when trying on Production environment
If you still wanted to get confirmation dialog for existing element please use the Version – 1 link:
http://axblog4u.wordpress.com/2010/1...r-dynamics-ax/
I have a made minor changes w.r.t existing version.
1) No Email support.
Instead, once the objects are imported the log file is opened automatically.
2) The log report shows the Imported User & User Preferred Time zone.
In the vNext – 3, I shall be adding new feature like:
1) Adding the imported object to the Project at run-time so that user can track the imported objects based on the time.
Download Link @ Version: 2
http://cid-264a0056cbcbb1d3.office.live.com/self.aspx/.Public/SharedProject%5E_MultipleXPOImport%5E_v2.xpo
Источник:
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите
личное сообщение
администратору.
Посмотреть профиль
Найти ещё сообщения от Blog bot
