Старый 31.03.2008, 14:43   #8
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
А попробуйте со след. содержанием метода update()
void update(boolean _updatePriceDate = true)
    boolean         updPrice;
    FormRun         formRun;
    FormObjectSet   formObjSet;
    int             i;
    InventTable     inventTable;
    if (this.orig().Price     != this.Price     ||
        this.orig().Markup    != this.Markup    ||
        this.orig().PriceUnit != this.PriceUnit)
        updPrice        = true;
        if (_updatePriceDate)
            this.PriceDate  = systemdateget();
    ttsbegin;
    super();
    if (updPrice)
        if (this.ModuleType != ModuleInventPurchSales::Sales)
            InventTable::updateAutoSalesPrice(this.ItemId, this.PriceDate);
        else
            if (this.isFormDataSource())
                // refresh and reread inventTable datasource if exists in form
                formRun = this.dataSource().formRun();
                for (i=1; i<= formRun.dataSourceCount(); i++)
                    if (formRun.dataSource(i).cursor().TableId == tablenum(InventTable))
                        formObjSet = formRun.dataSource(i);
                        inventTable = formObjSet.cursor();
                        break;
                if (!inventTable)
                    inventTable = InventTable::find(this.ItemId, true);
                if (inventTable)
                    if (inventTable.updateAutoSalesPercent() && formObjSet)
                        formObjSet.refresh();
                        formObjSet.reread();
    ttscommit;
метод updateAutoSalesPercent видимо сделали не статическим. Вот его код, на всякий случай:
server boolean updateAutoSalesPercent()
    InventTableModule   inventTableSales;
    InventTableModule   inventTableBasic;
    if (this.SalesModel == SalesPriceModel::None)
        return false;
    inventTableSales = InventTableModule::find(this.ItemId,ModuleInventPurchSales::Sales,true);
    if (this.SalesPriceModelBasic == SalesPriceModelBasic::PurchPrice)
        inventTableBasic = InventTableModule::find(this.ItemId,ModuleInventPurchSales::Purch);
    else
        inventTableBasic = InventTableModule::find(this.ItemId,ModuleInventPurchSales::Invent);
    if (! inventTableSales || ! inventTableBasic)
        return false;
    switch(this.SalesModel)
        case SalesPriceModel::Contributionratio:
            if (inventTableSales.pcsPrice())
                this.SalesContributionRatio = (inventTableSales.pcsPrice() - inventTableBasic.pcsPrice()) * 100 / inventTableSales.pcsPrice();
            break;
        case SalesPriceModel::PercentMarkup:
            if (inventTableBasic.pcsPrice())
                this.SalesPercentMarkup = (inventTableSales.pcsPrice() - inventTableBasic.pcsPrice()) * 100 / inventTableBasic.pcsPrice();
            break;
        default:
    this.update();
    return true;
За это сообщение автора поблагодарили: Starling (1).
