Источник:
http://www.agermark.com/2018/03/gene...hing-line.html
Tried to write a generic routine for switching line numbers on records, to help with functions that move records up or down according to a line number sequence.
Comments are welcome and I'll update the post according to the bugs you can find. However I only spent 10 minutes on this and it's provided to you for free, so please bear that in mind before you send me death threats in the comments.
public static void switchLineNumbers(
Common _currentTopRecord,
Common _currentBottomRecord,
FieldName _lineNumberFieldName)
#define.RetryNum(5)
Common currentTopRecordUpdate;
Common currentBottomRecordUpdate;
LineNumber topLineNumber;
LineNumber bottomLineNumber;
FieldId lineNumberFieldFieldId = fieldName2id(_currentTopRecord.TableId, _lineNumberFieldname);
try
ttsBegin;
// Initialize correct table id on common
currentTopRecordUpdate = new DictTable(_currentTopRecord.TableId).makeRecord();
currentBottomRecordUpdate = new DictTable(_currentBottomRecord.TableId).makeRecord();
select firstOnly forUpdate currentTopRecordUpdate
where currentTopRecordUpdate.RecId == _currentTopRecord.RecId;
// Make a temporary line value, in case there is a unique index with line number,
// making a free spot to update the currect bottom record with
topLineNumber = currentTopRecordUpdate.(lineNumberFieldFieldId);
currentTopRecordUpdate.(lineNumberFieldFieldId) = maxInt();
currentTopRecordUpdate.update();
select firstOnly forUpdate currentBottomRecordUpdate
where currentBottomRecordUpdate.RecId == _currentBottomRecord.RecId;
bottomLineNumber = currentBottomRecordUpdate.(lineNumberFieldFieldId);
currentBottomRecordUpdate.(lineNumberFieldFieldId) = topLineNumber;
currentBottomRecordUpdate.update();
currentTopRecordUpdate.(lineNumberFieldFieldId) = bottomLineNumber;
ttsCommit;
catch (Exception::DuplicateKeyException)
if (appl.ttsLevel() == 0)
if (xSession::currentRetryCount() >= #RetryNum)
throw Exception::DuplicateKeyExceptionNotRecovered;
else
retry;
else
throw Exception::DuplicateKeyException;
Use at your own risk.
Источник:
