Старый 13.03.2023, 16:11   #1
d365fokartik: DMT –  Use the Data migration tool to migrate from Dynamics AX 2009 to finance and operations – Part 2
Источник: https://d365fokartik.home.blog/2023/...ations-part-2/
Please note the file is saved as .xlsx. Please save as .xlsx and do not change the extension. When you give this as an input to the Default Configuration parameter value in the next step, select All Files to select .xlsx file. Failure to follow this step will cause downstream errors during generate mappings. 2. […]
