Старый 30.01.2017, 13:22   #1
Link is offline
Link
Британский учённый
Аватар для Link
568 / 523 (19) +++++++
Записей в блоге: 9
Да, спасибо, я искал документацию, и вот что удалось найти:
The Internal command-line parameters
Axapta has a number of command-line parameters which extends the formal and documented list of parameters. All of these takes the form -INTERNAL=something, where something denotes the flavor of the parameter. Below is a list of parameters maintained by the BackOffice Feature Team (links to whitepapers appear where appropriate):
-INTERNAL=NOCURSORREUSE Disable the SQL cursor reuse mechanism. Hurts performance, improves easy of tracing/debugging
-INTERNAL=COMMENTS Insert comments in the generated SQL showing the values of placeholders.
-INTERNAL=RELAXEDONTTSLEVEL Suppress the TTS level checking. Should only be used with care.
-INTERNAL=RELAXEDONUPDATE Suppress the checks on updates, and deletes (manipulating data which was not seleted locked)
-INTERNAL=UNIQUEINDEXES Force all Axapta indexes to be created unique (i.e. by appending the RecId column to the index). Requires the database to be re-indexed to be applied to the database.
-INTERNAL=SYSLASTVALUE Make the table SysLastValue be stored in Axapta internal storage (as opposed to the SQL database). For backward compatibility only.
-INTERNAL=SYSLASTVALUECACHE:cacheMode Overrule the default caching method on the system table SysLastValue. Default is 3 (“NotFound”), valid values 0 through 3. Used for testing and debugging purposes only.
-INTERNAL=MONOCASE Simulate the way the Oracle-version handles indexed fields, i.e. lower (“mono”) case the data. Used for testing and debugging purposes only.
-INTERNAL=NODATAAREAID Simulate the “SavePerCompany” table property to be “FALSE” on all tables. To be used in benchmarking.
-INTERNAL=NOSYNCTABLELOCK Don’t apply exclusive tablelock on a table being synchronized.
Еще есть для клиента:
-INTERNAL=NOMODALBOXES switch prevents Axapta from different pop-ups during the process.
За это сообщение автора поблагодарили: sukhanchik (6), Logger (3), Ace of Database (3), Raven Melancholic (2), gl00mie (3), -DocSerzh- (1).
