Старый 12.10.2016, 19:12   #1
organicax: Route feasibility error when resource not setup correctly
Источник: https://organicax.com/2016/10/12/rou...tup-correctly/
When you are setting up a route you can assign a resource and use the route feasibility function to see if the system can actually find the resource. If you get an error then you might want to check the resource setup.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
