Тема
tlefor: Dynamics AX 2012: Meet the Table Control
21.01.2015, 01:14
1
848
80
Источник:
http://blogs.msdn.com/b/tlefor/archi...e-control.aspx
Meet Dynamics AX 2012's Table Control. It's
an unbound control that offering unique interactions with
the user providing functionality not available with other "table or t
abular" controls like ListView and Grid. The table allows the developer
to swap underlying controls on a cell by cell
basis, and has the ability to show a large number of columns-defined
at runtime if necessary.
At
it's core, the table is a simple unbound table:
It
allows you to specify the number of columns/rows and as an option to show
gridlines. The table allows you to indicate which types of controls can be
hosted within each cell:
A
powerful feature of the table is in its ability to vary the input type per
CELL. This is done by the developer adding an edit control method that returns
the modeled control type that should be represented in that cell
Combined
with the capabilities of the individual controls, different visuals and
interactive uses are possible.
With the Table control,
the developer will be able to:
Model a table control on a
form
Set number of columns and
rows
Set height and width
Add supported contained
controls for interaction within each cell
from the AOT, select and right click on the control-
select add control
On a cell by cell basis, the
control calls the editcontrol method to learn what control to host in the
cell
FormControl
editControl(int column, int row)
if ((column == 2) || (column == 4))
if (row > 1)
return intEdit;
else
return editline;
else
return editline;
Источник:
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите
личное сообщение
администратору.
Посмотреть профиль
Найти ещё сообщения от Blog bot
