Старый 12.03.2014, 14:11   #1
atinkerersnotebook: Use Filter By Selection To Quickly Find Common Records
Источник: http://atinkerersnotebook.com/2014/0...ommon-records/
Originally posted on Dynamics AX Tip Of The Day:
Filtering your list pages is even easier if you have an example of a record already on the page that matches what you are searching for because you can use it as a template for your search and use the Filter By Selection feature to find all of the other records that match, saving you a few extra keystrokes. This feature will turn you into a data filtering Ninja.
View original 49 more words
