Старый 22.01.2013, 13:34   #2
Eloy is offline
Eloy
AX 2009 EP Lookup из enum
Как на портале сделать Lookup из enum.
В AxLookup в markup добавляем ContentTemplate.
PHP код:
                <dynamics:AxLookup ID="AxLookupType" runat="server" ShowFilter="False"
TargetControlId="txtType">
ContentTemplate></ContentTemplate>
dynamics:AxLookup
В коде:
using System;
using System.Collections;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using Microsoft.Dynamics.Framework.Portal.UI.WebControls;
using Microsoft.Dynamics.Framework.Portal.UI.WebControls.WebParts;
using Microsoft.Dynamics.Framework.Portal.UI;
using Microsoft.Dynamics.Framework.Data.Ax;
using Microsoft.Dynamics.Framework.Metadata.Ax;
using Proxy = Microsoft.Dynamics.Framework.BusinessConnector.Proxy;
using ApplicationProxy = Microsoft.Dynamics.Portal.Application.Proxy;
using Microsoft.Dynamics.Framework.BusinessConnector.Session;
using Microsoft.Dynamics.Framework.BusinessConnector.Adapter;
    protected void Page_Init(object sender, EventArgs e)
        this.AxLookupType.Lookup +=new EventHandler<AxLookupEventArgs>(AxLookupType_Lookup);
        this.AxLookupType.OkClicked += new EventHandler<AxLookupEventArgs>(AxLookupType_OkClicked);
    protected void AxLookupType_Lookup(object sender, AxLookupEventArgs e)
        AxLookup lookup = e.LookupControl;
        CheckBoxList    eCheckBoxList = new CheckBoxList();
        string iLabel;
        int myEnum = EnumMetadata.EnumNum(this.AxSession, "myAOTEnumName");
        using (Proxy.DictEnum dictEnum = new Proxy.DictEnum(this.AxSession.AxaptaAdapter, myEnum))
            for (int i = 0; i < dictEnum.values(); i++)
                iLabel = dictEnum.index2Label(i);
                if (string.IsNullOrEmpty(iLabel))
                    iLabel = dictEnum.index2Symbol(i);
                eCheckBoxList.Items.Add(iLabel);
        lookup.ContentTemplateContainer.Controls.Add(eCheckBoxList);
    void AxLookupType_OkClicked(object sender, AxLookupEventArgs e)
        string lookupValue = string.Empty;
        CheckBoxList eCheckBoxList = (CheckBoxList)e.LookupControl.ContentTemplateContainer.Controls[0];
        foreach (ListItem li in eCheckBoxList.Items)
            if(li.Selected)
                lookupValue += (lookupValue == string.Empty ? li.Value : "," + li.Value);
        e.LookupControl.TargetITextControl.Text = lookupValue;
