Источник:
http://blogs.msdn.com/b/axsupport/ar...st-met-19.aspx
Since October 1st 2012 the Netherlands VAT rate has changed from 19% to 21%. In order to update the NL VAT report in AX2009 & AX2012 to reflect this, the text on the VAT report needs to be changed from
'1a Belast met 19%' to '1a Belast met 21%' for the Tax reporting code 110
Here is the procedure how to do this for Dynamics AX 2009 and AX 2012
AX 2009
1. Go to the AOT\Reports\TaxReport_NL
2. Locate the method ''makeReport' and on line 9 change the text '1a Belast met 19%'; to '1a Belast met 21%
3. Save
AX 2012
1. Go to the AOT\Classes\TaxReportController_NL
2. On this class go to the method 'Fetch'
3. In here edit the label "@SYS310883'(rightclick on the label in the code and select lookup label/text) on line 20 for the language NL so that the label reflects the new VAT %.
4. Save
Источник:
