Источник:
http://www.dynamicscare.com/blog/ind...rm-2011-online
Fetch XML has a few limitations still which will quickly surface as you start building reports. You need to be aware of these: You cannot specify left outer joins – e.g. The following is not supported: “Select all Accounts who do not have a related Completed Appointment record” You cannot specify group by/sum queries – e.g. The following [...]
Источник:
