Источник:
http://gustafwesterlund.blogspot.com...lution-to.html
Today I was deploying a solution to a production environment and ran into a quite difficult problem; the custom report we had made could not be uploaded to CRM and the error description was rather cryptic. This error description was independent on if we tried to import the entire solution or just added the report directly. The error we received was the following:
Unhandled Exception: System.ServiceModel.FaultException`1[[Microsoft.Xrm.Sdk.OrganizationServiceFault, Microsoft.Xrm.Sdk, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35]]:
An error occurred while trying to add the report to Microsoft Dynamics CRM. Try adding the report again. If this problem persists, contact your system administrator.Detail:
http://www.w3.org/2001/XMLSchema-instance" xmlns="
http://schemas.microsoft.com/xrm/2011/Contracts">
-2147188072
