Сообщение от
oleg_e
......падает на следующей ошибке:
Deploying 0 data source(s) and 6 design(s) in 43 culture(s) (258 item(s) total)...
Unable to connect to
http://oleg:88/ReportServer/ReportService2005.asmx as specified in the config file for the report server at C:\Program Files\Microsoft SQL Server\MSRS10.MSSQLSERVER\Reporting Services\ReportServer\RSReportServer.config. If this url is not correct please update the config file, otherwise make sure the report server is configured correctly.
The deployment log file can be found at "C:\Users\oleg\AppData\Local\Temp\tmpF157.txt"
