Источник:
http://xplusplus.info/index.php/warn...ses-precision/
This warning appears when trying to convert
Real or
Int64 variables to
int, like in the following example:
info(int2str(emplTable.RecId));
emplTable.RecId returns a Int64 value, and by converting it through
int2str function we actually changing the data.
The solution is to use the correct converting function, in that case it is
int642str()
info(int642str(emplTable.RecId));
Источник:
