Старый 30.09.2010, 09:05   #1
25,751 / 851 (80) +++++++
sumitax: EP Debugging Tips and Tricks –Part II
Источник: http://sumitax.wordpress.com/2010/09...%80%93part-ii/
For EP Debugging on Windows Server 2008 R2 , make sure the following is set up in web.config for Debugging in VS2008 to work :
  1. In the Compilation tag , debug attribute should be set to true.
  2. In Customerrors tag mode attribute should be set to off.
Note: As an alternative to hand editing this file you can use the
  web admin tool to configure settings for your application. Use
    the Website->Asp.Net Configuration option in Visual Studio.
