Старый 29.05.2009, 00:13   #1
gatesasbait is offline
gatesasbait
Ax & C# programmer
5 / 18 (1) ++
Mazzy: I totally agree with you. If opening up calls to runbuf() for users, we need to be vary careful and remove any calls to functions that are not mathematical. Take for example the product builder, I do not believe it is secured, attack is possible, as well as when creating data import definitions, the conversion tabs are open for attack too.
KashperUK: True, the standard microsoft calc.exe is the ideal and safest calculator, however the idea of using runbuf() came from a brainstorm for a customer that needed a way to create custom formulas for forecasting in AX, I proposed using runbuf, I however will not be taking care of the actual project. The choice is up to them.
Great forum btw, and a very useful bot for the AX community.
