08.05.2008, 22:06
#1
axStart: InfoPath with default AIF web services
Источник: http://axstart.spaces.live.com/Blog/...C0A0!310.entry
Introduction
When completed this session you have created an InfoPath form that can interact with a Microsoft Dynamics AX Web service. On the end of this document we will use Microsoft Visual Tools for Applications for automatically generate GuidID and Source Endpoint User ID. Also enhancements to the AxdClass will be made.
Create a web service in AX
- Create the AOT query
- Click New Query in the AOT menu and rename it to ProjHours
- Drag the table ProjJournalTrans to the data source node of new Query
Save the changes.
NOTE: If you want to update or delete records with AIF, turn the update property on
NOTE: only Tables with a unique primary index will work correctly in AIF when you want to find, delete or update the record.
Creating the related classes- Click Tools/Developers Tools/Wizards/AxdWizard
- Click the 'Next' button and select the ProjHours Query
- Click the 'Next' button.
- Select CreateList and press the Next Button
- Select Regenerate existing AxBC classes and press Generate Button.
Click the 'Finish' button.
As you can see the generated code does not compile. You can remove the 2 non compiling methods.
Change class AxdProjHours method prepareForSave
This method is used for additional programming logic. In our casem we have to create a journal. We decide to make a journal for every week.
public boolean prepareForSave(AxdStack _axdStack, str _dataSourceName)
ProjJournalTable projJournalTable;
JournalID journalID;
axProjJournalTrans axProjJournalTrans;
switch (classidget(_axdStack.top()))
case classnum(AxProjJournalTrans) :
axProjJournalTrans = _axdStack.top();
//InfoPath Demo create journal in case not exist
journalID = strfmt("Week %1",wkofyr(axProjJournalTrans.parmProjTransDate()));
if(!ProjJournalTable::exist(journalID))
projJournalTable.initFromProjJournalName(ProjJournalName::Find("Hour"));
projJournalTable.JournalId = journalID;
projJournalTable.insert();
axProjJournalTrans.parmJournalId(journalID);
return true;
default :
error(strfmt("@SYS88979",classId2Name(classidget(_axdStack.top()))));
return false;
return false;
Create the new Web service
- Open Menu/Basic/Setup/Application Integration Framework/Action
- Click the 'Scan and register' button.
- Turn the Enabled and web Enabled option on for the createListProjHours Action
Press generate button
Turn directory browsing on in the IIS site of our web services. This makes it easier to investigate.
Create a new Endpoint for the action with additional authorization.
- Open Menu/Basic/Setup/Application Integration Framework/EndPoints
- Create a new record
- Endpoint ID = Hours
- Local endpoint ID = DMO
Select Tab page Constrains and turn option No Constraints On
- Select Tab page Users and add user group Admin
- Save the record
- Click the 'Action policies' button.
- Select the correct Action ID.
- Set status to Enabled
- Set Logging Mode to Log All
- Click the 'Data Policies' button.
- Click the 'Set' button.
- Click the 'Enable all' menu.
Don’t forget to set our new endpoint to active.
[FONT='Arial','sans-serif']
[/FONT]
Create an InfoPath document
Open InfoPath 2007 on the VPC. Select design a Form Template. Select Web Service and press OK.
InfoPath will open a wizard that helps you to find and connect the right way to our AIF ProjHours Web Service. In our case we will Submit Data. The web service is located at http://dynamicsvm/DynamicsWebService/ProjHoursService.asmx.
InfoPath will show a list of operations that will submit data. We can only select our creareListProjHours operation. We don’t change the name of this web service because it is still our main submit.
Designing the Form
Drag the fields to the form that you need. First we drag the DocumentContext node to the design. When dropping it into the design we select ‘Controls in Layout Table’
Next select the end of your document and press Insert/repeating Table.
Select the ProjJournalTrans record and press next.
Select the fields that are needed for the InfoPath dialog and press Finish
Finally give the CurrencyID a default value EUR , by double clicking on the CurrencyID of the datasource and entering the value. Programming in InfoPath
We have the general design for our InfoPath dialog available, but we don’t have match intelligence. It would be better if we dynamical generate:- MessageID
- Source Endpoint User
- Source Endpoint
Destination Endpoint
We can do this by using the Visual Studio Tools for Applications. Select Tools/Programming/Load event. InfoPath wants that you save first your InfoPath Form so we do that (call it ProjHours). Next a C# project is generated.
Go to the FormEvents_Loading method and add these lines of code:
public void FormEvents_Loading(object sender, LoadingEventArgs e)
string xmpPath = "/dfs:myFields/dfs:dataFields/tns:createListProjHours/tns:DocumentContext";
XPathNavigator xmlGuid = this.MainDataSource.CreateNavigator().SelectSingleNode(xmpPath +"/tns:MessageId", this.NamespaceManager);
XPathNavigator xmlEndPointUser = this.MainDataSource.CreateNavigator().SelectSingleNode(xmpPath +"/tns:SourceEndpointUser", this.NamespaceManager);
XPathNavigator xmlSourceEndpoint = this.MainDataSource.CreateNavigator().SelectSingleNode(xmpPath + "/tns:SourceEndpoint", this.NamespaceManager);
XPathNavigator xmlEndPoint = this.MainDataSource.CreateNavigator().SelectSingleNode(xmpPath + "/tns:DestinationEndpoint", this.NamespaceManager);
xmlGuid.SetValue(System.Guid.NewGuid().ToString());
xmlEndPointUser.SetValue(System.Environment.UserDomainName + "\" + System.Environment.UserName);
xmlSourceEndpoint.SetValue("Hours");
xmlEndPoint.SetValue("dmo");
Next Build (compile) your solution in Visual Studio. Close Visual Studio and do your first test in InfoPath by pressing the Preview button. And ……….. we get an error!
This error tells us that we are not allowed to check for the user and domain name. Think about secure x++ code you have to ask permission for it. So let’s ask for permission. Close the preview and go back to visual studio and add next line in the FormEvent_loading method
new EnvironmentPermission(PermissionState.Unrestricted).Assert();
Also add the library for this Class at top of your c# project
using System.Security.Permissions;
Now the code is ready for secure coding but our InfoPath Form is not trusted jet. To get our InfoPath trusted, do the next steps:- Select Tools/Form Options
- Select Security and Trust
- Deactivate automatically determine security level
- Select full trust
Select sign this Form and create a certificate (this is not mandatory as long you don’t publish this Form)
Preview your InfoPath form again and test the web service with next data
EmplID
RAV
ProjID
40010
CategoryID
Install
Qty
8
LinePropertyID
Charge
Testing, debugging & fixing
If you submit your data and you get an error. The information of this error is a little bit incomplete. Detailed information about the error is available in AX. Look at the Form at Menu/Basic/Periodic/AIF/Exceptions.
NOTE AIF will skip fields when the property allowEditOnCeate is set to NO, without any warning
Good luck
for dowloading the solution: Code + article in pdf format
What’s Next Next week we will redesign our InfoPath form so it can interact with AIF file inbound adapter.
In the final week we will introduce offline working and automatic synchronization and add lookup fields for selecting project, Employee etc.
