Старый 02.10.2007, 04:49   #1
Inside Dynamics AX 4.0: The Business Connector
Источник: http://feeds.feedburner.com/~r/Insid...connector.html
The Business Connector is a versatile platform component that you can use to build software applications that interact deeply with both the data and the business logic residing in Dynamics AX 4.0. The Business Connector consists of two components: the COM Business Connector and the .NET Business Connector. This chapter focuses mainly on the .NET Business Connector because it is new in Dynamics AX 4.0 and will be of interest to anyone who wants to develop managed solutions with Dynamics AX without using COM.
This chapter compares the Business Connector with other integration components included with Dynamics AX 4.0. It also explains the Business Connector architecture to help you understand how it functions. Several example scenarios demonstrate the variety of potential uses for the Business Connector. The .NET Business Connector managed classes are described and code examples are provided to illustrate their use. This chapter also describes how to port applications built with the COM Business Connector in earlier versions of Dynamics AX to the .NET Business Connector, and it highlights the differences between the two Business Connector components. </img> </img> </img> </img> </img>
