Старый 16.06.2007, 11:20   #1
jerry-dynamics: What tool would be appropriate to use before you click the button to import into AX 4.0?
Источник: http://jerry-dynamics.org/2007/05/20...priate-to-use/
Questions You have received an xpo-file containing modified application objects. What tool would be appropriate to use before you click the button to import into AX 4.0? A: Application Hierarchy Tree B: Application objects C: Code Explorer D: Compare
